Hi GUYS , Im new to this fourm , I have owned newmwerous Old alfa's Just bought a 156 2.0 TS.
I changed the Aux belt , and noticed that the balance shaft belt is missing :eek:, is this Serious , and can the motor get Destroid by driving it without this belt ??
O 1 more thin is the PK6 1980, Correct Aux belt
Thanks ;)
hi, it will not cause a problem without the belt, just have a bit more vibration at tickover etc, however ensure that there are no bits left that can get into the cambelt, also check when the cambelt was changed, if the balancer has failed, the cambelt may not be far behind it.
HTH
Phew :)Thanks for the Heads up, I think they didn't put one in on purpose,:) as the car has history , according to what I can see on the records they did the head , I can see some signs of "Creame ala Alfa" in the waterbottle and the Cam belt about 10 000 Km ago I do not see any sign of a balance shaft belt, that puts my mind at ease.
I still feel they had it right with the 2.0 164 TS ie. NO CAM BELT !! :cry:
I drive without balance belt. I think the engine gains a bit in power after you get rid of it. I also have not noticed any gain in vibration or sound of the engine.
Yep, some people remove the belt on purpose. if it had snapped its likely to have taken out the cam belt as well.
It will take out the cam belt for sure. So this is the main reason why i removed it. Also i don't mind a bit noisy engine :)
yeah works gr8 since ive got the car I put on a few thousand km's no issues I think i will leave it off on the next cam service Just the Im going to buy 1 plat plug a month ,here one 1 plug is 220 Rand ,so R 1760 ......:cry:
