hi to all
going to replace the alternator on my 156 1.8 ts, any clues on where to start, top or bottom or side? links, past topics any help would be cool:)
cheers
Tried the excellent search feature on here??
Try this one for starters ... link
thanks for the info, i think the petrol engines might be different this is what i had to do, remove drive shaft (drivers side) both bits, exhaust front bit to manifold (lucky its on flexi pipe as you can just hook it to one side), bracket from under the plastic inlet manifold and starter motor, i did not have enough room as the power steering pipes just got in the way, real pain of a job and without a ramp you spend a few hours on your back, but must say its well worth it no more squeal . . . . . . cool
hope this helps :)
