Hi everyone
Airbag light is on and had it diagnosed to be an internal ecu fault, been looking on eper for the part number but i've got 3 choices, coming from a parts background myself i know that there can be considerable differences, just wondered if anyone knows if it would matter for this ecu? and if so does anyone know how i can access the relevant codes on eper after entering my chassis number? My car is a 2000 model.
Thanks in advance :)
Matt
It depends on the number and types of the airbags, a 2000 usually only has 2 front airbags..
I can provide the part numbers if you give me the specs of the car.
Mine has the seat airbags and the drivers and passengers ones, it's a veloce model 2.0, any other info you need?
here are the part numbers:
you better check the number on the ACU (located on the transmission tunnel) to make sure
you order the right one !
60625180 68HC11E9
60631206 68HC11E9
60655033 04 305536 08AB32
60656767 68HC11E9
60658009 04 305536 08AB32
60663040 04 308087 08AB32
60663943 04 311020 08AS20
60664962 04 305536 08AS20
60665492 04 312040 08AB32
60669249 08AS20
60669250 04 313049 08AS20
60675876 04-320290 08AS20
60675876 04-320290 908AS60
60675880 04 320291 08AB32
60675876 is the current p/n or 60663943 if it was built before 15/11/1999.
