1 - 10 of 10 Posts
L
air-con ir non-air-con?
If non then consider looking at the relay to the passenger side of the centre tunnel, up behind the glovebox. Ortherwise it could be the resistor pack, located to one side of the fan assembly. also consider the fan itself.
hello
Thanks for your input.
Had the car in to a non-alfa garage to test things...
The fan works with direct current, we're not sure about the variable resistor, but the dial with the fan control, - - the middle dial on the 'radio' console - flickers on & off. I shall have to live with it till next week, which is a nuisance cos im travelling alot from tomorrow :(
Worth checking the big fuses in the connection box on top of the battery positive terminal.......
1 - 10 of 10 Posts
