My AC stopped getting cold, so in an attempt to fix it myself I checked the fuses. Started with the standard fuses under the dash. I noticed that the cigarette lighter fuse was faulty, so I replaced it and now the AC works 100s again... :confused:
is this normal
is this normal
I had it similar.
I also had the AC stopped cooling, I went to AC place and the guy said the motor does not kick in - he said he checked fuses - but allas seemingly had no clue - and wanted to rewire. Had the fuses fixed - voila AC motor kicks in, but still no cooling, so I went for a re-gas and this guy quoted me a new condenser and fixing a piece of pipe. Had the pipe fixed only and happy days - saved R2000.
My 156's A/C ran off the engine for some reason, it had an electromagnetic clutch that had to kick in. Apparently the following failure is also quite common: The A/C doesn't kick in but the light illuminates. All pressures are checked and they are right. If it doesn't turn out to be a fuse, check by supplying the green wire on top of the A/C with +'ve power. If it clicks, then you have a short on the wire from the relay at the battery, to the a/c compressor. I had the wire repaired and the a/c worked again at 100% efficiency :thumbs:
Normally if you have a gas leak the pressure regulator will cut the compressor out so always first check gas pressure.
No all saw good just that fuse, that should in my world have nothing to do with the AC... another problem I had was when I took my window switches out to re-con them the boot wouldn't lock???
I'd love to meet the lil Italian dude that wired up my Alfa, he must have a good scents of humour
