Where can I get one without being charged an arm and a leg?!?
Thought I'd found one really cheap, but that was for a Non-ABS hub .. but I didn't think Alfa made any non-ABS 156's?!? :confused:
L
[email protected]
you buy the 5 stud hub & bearing as a set, 36mm socket to open the nut, take of claiper & disc. some of the shell of the bearing may remain behind, cut a slot in the shell & slpit with a hammer + cold chisel.
Alternatively swap the assembly from another 156 but that too could have issues with ABS sensor removal or the 'long' bolt been ceased, as you may well know.
L
Alternative Autos [email protected]
you buy the 5 stud hub & bearing as a set, 36mm socket to open the nut, take of caliper & disc. some of the shell of the bearing may remain behind, cut a slot in the shell & slpit with a hammer + cold chisel.
D
Eurocarparts are about £58 with their current 25% off offer.
When I looked before xmas the cheapest I could find was abvout £67
Discussion Starter #5 (Edited)
£58.30 from Carparts4less ... slightly cheaper than ECP with their 25% discount code
Received today, Sat 7th Jan: It's a Lucas bearing kit: LKBA63014
