OK, firstly, a big HELLO! and note that this is my first Alfa 156, having shifted from years of VWs. I've got a 2001 'X' veloce 156, with FSH and 75k miles - as a whole, really clean..
However, when stuck in traffic, the temperature gauge shifts past the '0' on the '90' to some halfway point to the next marker (around 100C, I guess). The 2 fans kick-in and bring the temperature down to just past the '0'.
The temperature is held and the car never overheats and if traffic breaks-up and the car moves on, the temperature gauge falls back to around the '90' mark.
I have only ever noticed the fans working in high-speed, for a few seconds, switching themselves on and off as necessary.
Where should I begin (The Rad looks clean)?
each fan should have its own 'low-speed' resistor.
it is possible that BOTH low speed resitors are defective.
low speed licks in at 98, high speed at 103
Not to change the line of this thread and most of what has been mentioned is important, but whilst monitoring may temp gauge the other day i had Alfadiag conected and at the 90deg mark AD reported 90deg, but at the next mark 1/2 way between 90 and 120 AD 97deg, you gauge is a guide, but best to be safe than sorry, i also know i need a new Rad and i have a slight leak where the W****r who fitted my gas conversion broke into the cooling system i hope to Resolve this week...
That sounds fine to me, behaves similarly to my V6. Keep an eye on coolant and oil and you should be fine :)
