This is the next job after hopely sorting the water ingress on the A pillar,
Been told there should be a cable in the boot and that all Alfa's have it fitted.
Well I've looked under the bootcarpet, removed the upper trim , under the rear shelf and other than one two way connector each side theres no multi plugs unaccounted for.
There is a black box with a multiplug mounted centrally under the rear shelf which I can't indentify , what is it ?
Anyone able to tell me the colours of the cables I'm looking for? and possibly post a pic of the unit fitted in postition?
Do all Alfas have the changer cable fitted or not? I'd like to fit a matching Alpine unit and leave the radio cassette as standard and less attractive to the scum who wreck door locks etc to nick a CD player.
Keith
if you the vertical carpet on the drivers side of the boot you should fi nd the ca le there. Mine is a black cable with a round multi pin plug on the end.
thanks, found it all I need to do now is see an installation and get a changer
Keith
