Afternoon all,
So about 3 months ago I had the clutch done on the car under warranty :D (71K)
Time has passed, children have been born etc.
The clutch pedal for the past month + has been doing rather wierd things.
Slightly notchy, really heavy or nice and light and easy to use.
Could this be the??
Clutch and / or Flywheel ?
Master Cylinder?
or
Slave Cylinder?
Thanks all :thumbs:
Hi, any idea somebody?
I have the same issue with my 156(same engine), clutch was done 1 week ago and since then doing this.
The mechanic sprayed some grease to the top of the pedal and stoped but 3 days later did it again, so now I have the grease spray in the boot and keep spraying it, but this solve the problem just temporary...
Wahooo not just me then.
I heard some where that if a new clutch is fitted, it can blow the seals in the master cylinder?
TRUE? who knows?
you are going to have to pour a heck of a lot of oil down the shaft to get it into the bottom bush as there is a big flat stop just above it and oil will have to some how overcome this.....i recon itll drip of it and be nowhere near the bush
when a new clutch is fitted a mechanic should clean and grease the bottom bush and the top one and the fork the release bearing fits on..........my clutch is very light and very smooth as i did all this when i changed my clutch
Since posting the damn pedal is super light...................... :lol:
Shall have to monitor why it does it, Ambient temp, city driving, long journeys etc etc..
Cheers all
