Hi, everyone,
I started to experience a problem with my engine, seems likely a problem with the turbo
when the engine is runing below 2000 rpm on the road, everything is fine,
but when it runs above 2000 rpm, some noise like "si" will come from the bottom of the engine, serious smoke will be at the rear of the car , and accelerate flat .
When it is running on the road, gear 3 or gear 4, around 2300 or 2500 rpm, I can feel clearly that the power from the engine is like a pulse with a interval of around 10 seconds.
I think it may be a problem with the turbo or control system, does anyone have any idea of it ? how to fix it?
Thanks in advance
Hi, Abarth Sav, thank you so much !!!
Yesterday evening, I checked the pipe, it was exactly as what you said, it had got split on it, I used instant glue to seal it for the moment, it was back into power immediately
I checked with halfords, unfortunately they do not do such pipes, will check on line for a possilbe supplier.
Thanks again
