The multi plug on my throttle body has had a wire come off due to the throttle cable pulling against it, I have soldered it back but as its right at the base I need a new plug or the loom its connected to, does anyone know where I can purchase either or what they are technically called? Cheers:thumbs:
Is this one of the two large connectors on the top of the throttle body? That's the ECU and you'll probably find you have to replace most of the wiring loom ....
No those two are fine its the one underneath that is the same size as the upper two! Thanks for your help
