silly question i know but...
where's the idle control valve hide?
my car does a similar thing... every time you jump off the throttle (clutch in) the revs drop right off, splutter a bit and jumps up to normal idle, almost a stall... some times actually does stall... but usually almost... been the same for a yr and a half so far not got any worse... so i dunno if it is.
i had a rake about and cleaned up the air sensor (the tube thing with cross hatching matrix and a sensor on the inside on it's own, half way from air box to engine) but that wasd ok gave it a clean anyways... was that it? i kinda gave up thinking that the next box looked kinda tricky to play with... is it in this?? oh joy
marlon was about when i had a rake about and we both came up stumped... it must be really great when you know all this stuff
btw i'm running a 2.0 16v TS 1997 'P' reg
rgrds
J
