hi guys
there was a little bit of water in the wires that lead up to the box.
but not a drop in the box. the fuse was ok and the key sensor was plugged in.
i un pluged the alarm and the lighi did not go out so i would say that the alare has no afect to the code light. all i can think about is code code code co code code code code code code depodrtpqj reoijsefpojkf can this be fixed.
:eek: :eek:
Suggest a search through the Archives of 155.com ...........or maybe try searching on here for CODE am sure there are some answers to your problem in there :D
Btw your battery terminal`s are clean and tight even all the little wires on the positive terminal ;) if you got a poor connection then it might not getting the right voltage to power the Cose system up
