listen up boys its a piece of cake simply remove the 2 10mm bolts that go through the middle of the hinge and then the door will lift off and the lower half stays on the car (the bit held on by alan bolts) it takes a bit of wiggling 2 break the seal so as speak! it took me about 15mins 2 change the rear and about 20 for the front and wrinx i didnt wreck the wing! ha ha ha :cool: :rolleyes: :D
Discussion Starter · #2 ·
I still don't get it :rolleyes: Ah well, gotta do the offside doors on the twinny soon so will have to play again...and I cant wreck the wing this time!!
JB told me the same the other night :rolleyes:
wrinx
Wrinx
Mr Warriors right, when the door is fully open, you'll see the 10mm stud heads, undo them and take them out (the door won't fall off), then knock out the pin for the metal strap that stops the door opening too far, then simply lift the door upwards. easy....
