1 - 1 of 1 Posts
Hello Guys.
I have a problem with my 155 16v 2.0 ´97. It doesn´t start in the mornings. The only way I can make it start, is unplugging the air temp sensor, starting it (starts perfectly) and the plug the sensor again after 20 secs. Once it started, it starts fine all day long. The problem begins again on the next morning, every day:confused: . I replaced the air temp sensor, but it keeps doing the same. If I don´t unplug the sensor, it starts, but only after 10 attempts and with rough iddle and fans start for 5 secs.
Any ideas? Could it be the cam angle sensor? If that sensor fails, would it start unplugging the air temp sensor, as mine does??
I will appreciate any help!!
Thank guys!
1 - 1 of 1 Posts
