CAN I PUT A Q4 ENGINE ,REAR AND FRONT SUSPENSION INGLUDING THE REAR SAFT FOR 4x4 DRIVE
INTO A 1.8TS 8V.I HAVE FIND A CRASHED Q4 AND I GO TO TAKE ALL THE GAR.ANYDODY KNOWS IF I CAN DO IT?
Anything is 'possible', but I think you'll need to be very handy with a welder, since I think the bodyshells are quite different.
The rear suspension mounts are different, the fuel tank is in a different place and I guess the transmission tunnel has to be different to accomodate the prop shaft.
It's worth a go though, and since you already have the two cars and all of the parts, you can try it to see what fits!
Good luck!
you'd be better converting a Dedra integrale into a Q4 or putting the Q4 engine\fiat coupe 16vT engine into your 155 as FWD.
Yep,agree with f2g.
Don't bother with 4x4,I think
it would require a hell of a lot
of work to get it all together.
Just drop the q4 lump in and stick
to FWD,not sure how you would get
around the diff problem though,
can you run just the fronts
from it :confused:
