Some problems I discovered today:
- Door locking mechanism dead. (replaced relay, still dead)
- Can't open passenger door, drivers door can't be locked.
- Wipers always on. (it was raining)
- Interior light goes on and off while driving.
- Engine keeps running with the ignition off, stops when I turn on the rear window heater or if I put it in reverse.
- Broken fuse. (lights)
- Odometer erratic. Sometimes it just start to move, with the ignition off.
- Clicking relays under the hood. I guess fuel-pump relays etc.
Because there is a lot of moist in the car I suspect water is the culprit, though I can't seem to find any water leaks.
Engine runs fine, it's just hard to turn it off.
Any idea where to start?
