going to change the cambelt andpump on my mjet jtd, whats the best brand to use?
is there an uprated one thats less likely to break in the future?
I know that SKF produce quality bearings so if you can get hold of an SKF water pump you might be onto something. Saying that, changing the water pump/timing belt at the correct interval (60k Alfa recommended) is the real trick here, personally I'd change them every 50k just to be sure. As for the belts there's a lot of choice, Denso, Dayco, SKF etc, for peace of mind I'd just buy one from a specialist like Autolusso, AlfaWorkshop or Shop4Parts because they know what does and what doesn't cut the mustard. :thumbs:
I recently did the belts, pulleys and water pump in my 156 1.9 16v mjet and used Gates parts. I have used Gates parts for many years and many cars (mainly classic Yanks) and have always been pleased with the products. Some belts from other makers can feel very hard/plastic which i always try and avoid as they are a bugger to stretch and put on...lol!
Gates auto catalogue
We can supply cam belt kits SKF cam belt kits and Bugatti water pumps.
Please see the links below
ALFA ROMEO 147 ENGINE PARTS TIMING BELT KIT
ALFA ROMEO 147 COOLING SYSTEMS WATER PUMP
