1 - 2 of 2 Posts
ive replaced thr clutch master cylinder and jus 3 months later the pedal went flat to the floor again garage jist bled the clutch system and the pedal was hard again its soft on long trips but very hard in city driving?is there
a leak or slave cylinder???
cheers
Sounds like the slave. If the leak is only small you will be using the clutch lots so won't have time to leak out and make pedal go soft where as on long journeys you won't be using it as much. They quite often fail after the other is replaced
1 - 2 of 2 Posts
