After having only done about 700miles in my 147 it gave up on gears whilst driving home on friday.
Car was recovered to PVS in Nottingham they are not Alfa specialists so I may call them on Monday and direct them to the selespeed guides posted here.
Car drove fine from Birmingham to Nottingham, then when I came off the motorway (fully warmed up) when I pulled away on the roundabout it dropped from first into N.
Would then not reselect 1st or any other gear with the engine running. Just beeps and stays in N.
With the engine turned off I can go through all the gears 1-2-3-4-5 N and R without any problems.
After waiting a while creating a mini traffic hazard on a Friday afternoon I tried to pull off. 1st gear selected and pulled off, but then when I tried to change up it just dropped into neutral. Waited tried again same thing happens.
While waiting for the recovery wagon had a look under the bonnet. The selespeed oil is on the minimum mark.
Have ordered a diagnostic cable which will turn up next week.
Hopefully it will just need oil topping up and clutch rod adjustment check.
Anyone experienced the same thing? Or have any advice other then the guides in the stickys and the diagnostic here Alfa Romeo Selespeed - Home
Thanks in advance
Thanks in advance
