Hi all,
I hope it's OK to ask and certainly hope I've posted in the right forum but I'm in the market for a 147 at the mo.
I was quiet happy just pottering around waiting until the right one came up and then started seeing threads in various forums about the selespeed gearbox.
These problems seem to range from gear selecting issues to failure messages on the dash etc. 6 years old 147's with under 50k on the clock with full service history to older models and everything in between seem to experience some sort of issue.
When I'm looking at a 147, can anyone shed some experience/light on any tell tell signs of a gearbox that's about to misbehave? Anything I can do when I'm test driving it to highlight potential problems?
Or would it just be safer to avoid the Selespeed model and opt for a tradition 5 speed manual?
Any tips, advice would be greatly appreciate and thank you :)
selespeeds arnt get a bad press they dont deserve, they just need the odd bit of maintenance to keep them working as they should, its usualy lack of knowlege or people fixing them that causes problems, take it for a test drive and check the clutch action is smooth on take off and all the gears engage quickly and smoothly and no whining noises or crunching also check no warning lights on dashboard obviously other than that buy it and enjoy it..
I have a sele for 9 years now ! and no problems whatsoever, I use my alfadiag once a year to monitor settings and keep the Tutela reservoir topped !
Don't let the average mechanic anywhere near a sele !
Thumbs up for a sele :thumbs:
see if you can get somone to recommend a local inde garage near you then you cant go wrong. double check the belts have been done and theres no odd noises eg. suspension creeks, selespeed pump wyne and make sure the wipers work firmly you should get one privatly for a decent .
good luck
Fantastic!
Thanks for the advice guys, I'll certainly keep them in mind when I'm checking out a car :)
Thanks again!
R
had mine since march 02 plate great car check with laptop now and then no probs
