Hi all
Slight problem! the rear wiper has stopped working.
Worked but now dead. Any ideas???? or do I need buy new wiper motor.
Grateful for any input.
Check for fuses first, should be fuse 52 in the box under the steering wheel.
Did the wiper have any change in operation, maybe going slower or stopping in the wrong place before it packed in?
Hi
Thanks for the input. The fuse is al-right but, to answer your second question, the wiper did change operation and stopping in the wrong place!!!!
Do you know why?
They are terrible for clogging up the gears. Take it out and take the panel off the back, give it a good clean out, re-grease then re-install.
Had to do this twice to mine now but works fine after its done, untill it cloggs up again.
Hi Boyko, sorry, just saw your reply, sounds like a case of motor, or as andyg said, clogged gearbox, hope it's not too much of an effort to get it fixed
