Is it normal for the slide pins to have a rubber cover on the pin not the flexi outer cover? The bottom pin has the top one is a normal pin (rear calliper)
Discussion Starter · #2 ·
No one had the rears off and noticed or has someone just used a pin from something else :confused:
Thanks guys not come across them before and the fact there was only the one got me wondering.:thumbs:
Yes it's normal. Rubber sleeved, shorter pin at the bottom - plain, longer pin at the top.
I read somewhere that the short pin should be the "trailing" i.e. second pin in the direction the brake disc rotates...so as front calipers are always flipped the other way around to the rears like this F O) (O R the pin will be at the top on a front caliper. Can anyone confirm this? I didn't notice which way up they were during disassembly and there's a lot of conflicting information elsewhere.
PS ePer is no help as it seems to expect you to buy the whole bracket with the pins in it... no sub assembly showing exploded parts.
