Hi guys.
Anyone know where the gearbox filler plug is on a 1.9 JTDm with a Q2 diff?
The reverse light switch is on the top, near the gear-change mechanism if that helps.
I've read about a dipstick but can't see one.
Doesn't seem to be where it was on my old 1.6TS.
Thanks.
L
you fill it via the dipstick, which is located at the back of the diff/gear box.
best to put it in using a long tube & a 1/2L bottle feeding the oil into the tube. Let it gravity feed. Holds 2 litres
L
I top it up via the reverse light switch hole - take out battey, remove battery tray, unscew reverse light sensor and then pour in 2 litres of gearbox oil.
Thanks guys: found the dipstick but didn't have a tube to reach it! Poured in through reversing switch hole as suggested by Lacken156: just need to do it slowly.
