The heated rear window on my 147 doesn't seem to work. The light on the switch comes on (either when pressing it individually or when pressing the defrost button) but the window doesn't demist.
Is this a common fault and if so what is the fix?
Jon
Jon
Jon have you checked the fuse and the connections to the rear window? May be a loose wire or something.
mine doesnt work either... the elements have all (bar 2) fallen off!
im sure ill get it sorted one day... might be worth checking on yours that the elements actually are there
I took a look at the elements on the screen this morning and they are all broken in at least one place, some have peeled of almost entirely.
I presume the only fix is a new rear screen?
Is a rear screen normally covered under the windscreen portion of your car insurance?
