1 - 12 of 12 Posts
M
I found a complete superflex bush kit on ebay
http://www.ebay.co.uk/itm/Alfa-Romeo-Full-Suspension-Bush-KIT-RED-POLYURETHANE-/271103345178?_trksid=p5197.m1992&_trkparms=aid=111000&algo=REC.CURRENT&ao=1&asc=14&meid=5448268544375116477&pid=100015&prg=1006&rk=1&sd=271103345178&
As a ball park figure how many hours would it take a good mechanic to fit all of this?
The reason I ask it that its just shy of £300 for all the usual suspension suspects to be bought new and probably wouldn't take too long to fit as a complete unit, however the bush kit is around £200 but may take longer to fit due to labour of actually pressing the bushes as well. Im trying to do a cost comparison as I know the poly bushes would last longer so are better for the long term however I dont have the money to fork out for 10 hours of labour to press the bushes.
The pressing itself is fairly fast+straightforward with access to a hydraulic press. It's when diy'ers (like myself) try to accomplish the same with a sledgehammer and makeshift tools that a lot of time can be wasted on a single bush that just..won't..budge:mad:
It's StrongFlex. :)
Anyway I have those red ones on the rear and like them very much. Red ones are as soft as rubber. Yellow are much harder - they call them Sport.
As mathias says umit can be a pain if you don't have the right kit
M
Thanks for the reply chaps! As an alfa newb it really helps having a forum like this especially having a GTA which is, as im figuring out a potential money pit.
M
Parts bought!
Upper & lower wishbone bushes
ARB bushes
Droplinks
so should be a little less rattly, clunky and squeeky :)
Would love to but I don't have a garage, drive or anything to stand the vehicle up while I removed the parts. It would also be a challenge avoiding boy racers on the race track (I mean housing estate) lol.
C
For the upper arms, we use big, thick washers, nuts and a length of threaded bar...
No, not at all, they are pretty much the same as the original rubber bushes.
Exactly. Especially the red ones are soft.
I was using the same method for the rear trailing arm bush. Using a stronger steel threaded bar and nuts is essential though. Damaged two basic ones.
1 - 12 of 12 Posts
