Hi. Can anyone tell me when the Q2 diff became a standard feature and if there is any visual way of tell if a GTA might already have a Q2 fitted? Presumably then the non Q2 GTA's had open diffs? Would a wheel spin on grass confirm that it has a Q2?
Thanks guys.
I dont believe they were ever a standard feature of the GTA in either 147 or 156 guise. they were only standard on Q2 editions of the GT coupe and 147 .
the re is no visual way to tell if a car has been Q2'd but push one hard around a roundabout and it wont understeer so much and the VDC wont cut in so quickly.
perhaps a crude method to see if it has a Q2 but i cant think of an other one
H
accelerate hard round a sweeping corner and you will feel pulled tighter into the bend, rather than it pushing outward, its a pretty obvious difference so should be easy to tell
Thanks for the feedback. I spoke to my local dealership today and the technician said that as far as he knew they all had a limited slip diff. Is that true. If so is a LSD the Q2 or are they two different animals?, I spun the wheel up in the grass today and it left two even marks so it must have a LSD of sorts... Were the standard setups open diff types?
Thanks guys
Thanks guys
I think your local dealership technician is wrong, the Q2 is an LSD but the standard diff is not. :)
No 147/156 GTA's had any type of LSD from the factory, ever, if yours has one it's been put on by a previous owner :)
