1 - 20 of 322 Posts
Image1 by chris147gta, on Flickr
Image2 by chris147gta, on Flickr
Interior needs a going over with saddle soap;
IMG_7089 by chris147gta, on Flickr
IMG_7093 by chris147gta, on Flickr
IMG_7096 by chris147gta, on Flickr
Another reason to pull the cam covers off (oil leak) Or is it just from clumsy topping up? Meh.
IMG_7113 by chris147gta, on Flickr
The wheels are wearing 215's for some reason and juding by the receipts it has been for most of it's life. They're also looking very dull, as are the (305mm) brakes;
IMG_7099 by chris147gta, on Flickr
Shiney (post Dad's efforts) front wheel
IMG_7102 by chris147gta, on Flickr
The os front keeps rubbing against the liner. The non GTA lights and used to be silver front bumper suggest front end damage but I think this is just down to the wing suppor/leg being twisted out of shape because the bolt in the bottom siezed.
IMG_7108 by chris147gta, on FlickrThe other side is equally grubby;
IMG_7107 by chris147gta, on Flickr
The suggestion of a light front end is also evidenced by the headlights and the moisture in one of them. The front end is straight otherwise :)
IMG_7119 by chris147gta, on Flickr
Image5 by chris147gta, on Flickr
Image3 by chris147gta, on Flickr
IMG_7128 by chris147gta, on Flickr
Discussion Starter · #8 ·
IMG_7176 by chris147gta, on Flickr
It's by no means clean, just cleaner... New stainless bolts fitted and various brakets have been cleaned up;
IMG_7195 by chris147gta, on Flickr
IMG_7196 by chris147gta, on Flickr
I think the clean bits just highlight the rest of the mank...
IMG_7207 by chris147gta, on Flickr
IMG_7208 by chris147gta, on Flickr
Replacement GTA headlights and 5000k HID's fitted.
IMG_7211 by chris147gta, on Flickr
And the bonnet catch has been given a thorough clean...
IMG_7177 by chris147gta, on Flickr
Discussion Starter · #12 ·
Sodding thing gave me a right scare a couple of days ago. Leaving some traffic lights I gave it a boot full of revs then changed up thinking the rev limiter had cut in earlier than expected. Next thing, MCSF!!! And a beep every 30 seconds.
Now, if you said to me this had happened to you, I would diagnose the fault as being the wiring to a coil pack. Particularly if you mentioned that you've had them all off to paint the cam covers... But el panic here was convinced it was cam timing, "it's jumped a tooth, it's not misfiring at idle, it's not showing mcsf at idle, it's jumped a tooth"...
It was a coil pack. And despite the seller's most sincere assurances that the belt and tensioner have been recently changed, it's having new ones just for my own peace of mind. (The tensioner doesn't look like its new)
Discussion Starter · #14 · (Edited)
After playing 2nd fiddle to the 75 over the weekend (Still haven't been able to bleed the sodding brakes!) I was obliged to look at it last night. - Finished work and wandered over to my mate's garage to work on it.
Replacement front pipes fitted (flexi's were blowing)
New handbrake cables fitted (cable snapped sunday)
Discussion Starter · #15 ·
Tonight I mostly fitted a denison ipod link and usb port;
IMG_7388 by chris147gta, on Flickr
IMG_7390 by chris147gta, on Flickr
IMG_7406 by chris147gta, on Flickr
The engine mount I ordered yesterday afternoon from Autolusso turned up today (Thanks guys!:thumbs::thumbs::thumbs:) so I fitted that too, pic is of the worn out one (obviously)...
IMG_7393 by chris147gta, on Flickr
And my Dad has been busy;
IMG_7397 by chris147gta, on Flickr
IMG_7401 by chris147gta, on Flickr
IMG_7403 by chris147gta, on Flickr
You're sorting that car out properly :cool:
What's the 2 wires coming out from under the bulb holder in the last pic? Are you doing some angel eyes or reflector back-lightning or something, or is it just me being lost with 147 GTA headlights that I've never seen IRL?
Discussion Starter · #17 ·
My dad has retrofitted the projector lens to a standard headlight. The wires control a solenoid that moves the beam cut off out of the way on full beam (bi-xenon)
Banned
Makes sense that :thumbs:
I've got some brand new headlights still in the box, if I send them to you could you guys do the conversion at all? :)
Aah, that possibility didn't even cross my mind. Good idea.
*getting crazy thoughts about gta'ing headlights and retrofitting projectors at the same time, wallet trying to crawl away and hide*
Where did you find the projectors? some generic model at a reasonable price or remnants of some other 147?
Edit: read your thread in the GTA forum and have full understanding if you don't say what projector you used
Discussion Starter · #20 ·
Kind of. The car was fitted with OE xenons and has the levelling system. But it's been "modified" to take standard headlights. I had the day off today, spent 8 hours working on it with my dad but I don't feel like I've really achieved anything.
We started by taking the bumper off, again, and looking the original wiring to the OE xenons so that we understood what had been done.
On finding it my dad sighed and said "I'll go and get the wiring diagram"...
I've obviously got some problems with the clutch and this doesn't look good in terms of the gearbox's health;
But on further investigation it may be coming from elsewhere;
I also found another slight leak. - These newfangled alloy radiators don't appear to be worth it. The bottom rail is made of steel by the looks of it. It's corroded and the radiator looks like it has a leak from the bottom nearside corner. Ill be replacing that with a bogo copper one!
*wonders whether the thermal conductivity of copper is better than alloy.
Last time I looked at the clutch slave I did think about swapping it out but I can't remember if I did or not. Thought it would be worthwhile trying one before ripping the engine out to change the clutch and cambelt...
I took the pictures before apply pressure to the eazi bleed and before the lid on the reservoir started leaking brake fluid everywhere. #frantic 5 mins dragging the hose pipe out to wash it all off the underside of the car.
I knew the headlight sloshers didn't work from previous expeditions behind the bumper;
Bottom (broken bit)
Again my dad, rather ingeniously has repaired it *touch wood* using a bit of a core plug, some araldite and a hose clip. I thought I'd taken a pic of it but apparently I haven't.
The windscreen washers and the rear washer don't work very well. They're a bit limp at best. I thought it might be a problem with the pump but testing and replacing it has proven otherwise. We think it could be a problem with the non return valves but I can't see both of them failing.
Looking forward to fitting the projector lens lights tomorrow. :)
1 - 20 of 322 Posts
