1 - 2 of 2 Posts
Hi people,
I've had a few vdc system warnings and the occasional time where the front right has activated the abs and grabbed the brake (low speed) so. . . .I'm pretty sure I've narrowed down my problems to the sensor it's self, I've replaced the battery the other week so I know it's not that.
where about's is the sensor located?, and is it an easy enough job to replace?
AL
take front wheel off and look behind the disk at right hand side........a 10mm bolt holds the sensor into the hub
wire then runs to enging bay close to passenger side bonnet hinge
they are not cheap and u wont get it out in one piece....they are plastic u will prob have to drill it out when u have snapped it
1 - 2 of 2 Posts
