Hiya alfisti.
I have a donk on the front nearside. All bushed with polys and all good.
It's a heavy going donk and i wondered if it was the engine mount? Anyone had the front nearside or rear one go?
I've changed rear mounts on 156s - worth having a poke around under there to see if there is any movement. If it has gone you sometimes get the driveshaft hitting the subframe under extreme bump-loads....
If the box has been out and the rear support bar between the rear mount and engine/gearbox is left off the mount can rock causing a clunk which in turn damages the mount to gearbox threads.
Up on the ramps.....:eek:
Steering rack bolt hanging down by 20mm!!!! Spent the next hour going round every single nut and bolt making sure it was tight!!!
