1 - 2 of 2 Posts
Apologies if this has been dealt with a hundred times, couldn't seem to find the same issue on here already...
The driver's window on the 147 has stopped working completely. When I push the button to drop it I can hear the "beep", but no movement and I can't hear the motor either, so I don't think it's the runner sticking.
I think the switch is alright too, as the same button also operates the rear driver's side window, and that's working fine.
All the other windows operate fine. Where should I be looking? Could it be wiring, or more likely the motor's had it?
Check the fuses, if you can pull the switch and test it with meter. If all checks out, get the door card off and have a gander at the runner, motor, cables, connection block etc and test the wires at the connector if nothing obvious.
If wires in door dont check out and then ive used a 12v battery on the motor in the past, if it moves, u know it isn't the motor and thus must be the control module or other such gizmo in the circuit.
Logically run through bit by bit will surely identify which is causing issue.
1 - 2 of 2 Posts
