My 52 plate 147 has just started to make a horrible knocking noise when i open and close the door!! what the hell is wrong with it and how ca i fix the problem??
There's normally a bolt where it joins the car pillar and one on the door, they can appear tight but will take some more tightening when you get a spanner on them.
I have had a quick look!! to tighten the correct bolts do i need to remove the inside door panel or are they the bolts holding the strap to the outside of the door near where the strap leaves tthe door to connect to the car? a pic would be lovely? as you can tell im useless!
Just had look at mine 2001 VELOCE, 156 it would appear that there are 2 aln bolts per hinge, very difficult to access them, without a special tool..My drivers door needs tightening, as there is a bit of a knock at the half way open position.
Hi biggus,take a look on page 60 in here at thread by tian147 all the info plus pics you need to sort this ,did mine from this easy job too,sorry cant post link as computer playing up,
ash
