1 - 20 of 37 Posts
I have had my 147 for a few days; I havn't been able to get the Cruise Control to work yet, I have been pushing the clicker onto 'on' but nothing works...
is this a common problem or any are there any common fixes or things to look at. Any information is greatly appreciated.
Thanks in advance...
Lee
Try doing a search, there are loads of threads on this.
1) Are you using it properly?
Leave the inner switch in the 'on' position. You then have to flick the outer switch to '+' to activate the CC. You get a green speedometer icon on the dashboard
If not..
2) Check the fuse (f35 - second from right in top row of fuse box under the dash)
If not ..
3) Get your head in the pedal box.
There are position sensors on the clutch and brake pedals which deactivate the CC when you press a pedal. These often get misaligned and trick the system into thinking you have your foot on a pedal and stop the system from activating.
They look like white cylindrical plastic things with a little black plunger at one one end which is pressed in by a flat bit when the pedal is up. I fixed mine my gaffa-taping a couple of 1p pieces to fill the gap!
Good luck
Thanks very much for the quick reply.
Number 3 worked - i blue tac'd 2 pennies together and bluetacked them to the end of the pedal, however i am scepticle that they may fall off, what did you use to get a good solid connection so the pennies stay in place.
R
just buy some new switches about £18 each and bob's your mums brother!! However I sometimes have no cruise control during damp weather?????:lol:
F
When the circlip on my 147s' clutch pedal broke and the pedal returned fully home it fully depressed the ratchet mechanism on the switch and the Cruise control also failed to work.
All it took was to hold the pedal in (after it was fixed) and pull the switch plunger fully out and then let the pedal return. All fixed and working again.
I have tried to pull the switch out with some pliers, but i cannot get it out and i dont want to pull it for fear of breaking it, does it need some brutal force?
thanks
thanks
If it is stuck in then it will probably stick again. Like rhett71 said buy a new switch for 18 bucks, it's one of the cheapest replacement parts there are
The switch on my old 147 wouldnt come out either, so i cut down a fridge magnet and stuck it on the wee ledge on the clutch pedal :cheese: worked perfectly.
where exactlly it supose to apear ? does the car have to be in move, or I can check it on nutral ?
I'd play (pull them out) with these switchs and didn't see anything.
I'll replace it if I'll know that it going to solve the problem.
About the fuse reasone - Doesn't the computer have to give some alert ?
on the 156 it comes when when you switch on CC, but I believe on the 147 you have to actually have it operational (i.e. switch the switch on and press the speed up button whilst moving ...)
have you tried reading the manual??? Seleziona un modello - Libretto Uso Manutenzione Alfa
as said when ur moving switch it to the on position
then hold the increase speed switch
then you should see the car go into cc
you get the green icon where it shows ur clock on digital display
ok, i've answer for the first qeustion ?
For the second one, i neeed an explanation. should I've to be on driving to see the green icon, because I want to check it (fuse, switchs ...) I can't do it while I'm driving .
Two comments here.
Firstly, the cruise control will operate (well, mine will!) at any speed above about 25mph.
Secondly, there are two different systems on 147. On the earlier ones the icon appears (on the display in the centre of the dash if I remember correctly) when the cruise control is switched on. On the later ones the icon appears in the speedo only when a speed has been set.
Common causes of non-functioning cruise control are incorrectly set or faulty clutch or brake light switches. A search will bring up several threads on either.
yes mate u will need to be driving to set the cruise control u cant set it when u are parked.
have you tried doing what i posted when your driving?
put it on then hold down the + speed lever
it should come on
Adam
No, it doesn't come. tomorrow I'll check the switchs again, and I'll try to put somthing in the gap.
Didn't check fuse or conectors yet.
I've the erlier model (2002)
Yes, it's work. great.
This happen after my mechanic told me that it often failed and nothing to do with it, and the previous owner's mechnic told me that this car doesn't have CC.
This forum is graet.
Now the next problem is flashing odometer. I'll look forward for a solution.
On mine, light wouldn't come on and cruise wouldn't work.
I had earlier removed clutch pedal linkage to get rid of squeaky clutch pedal.
I found it easiest to:
Find switch on top of clutch.
If clutch pedal not touching switch, then that's the issue.
Twist switch half a turn anti clock wise and it pops off the holder.
Disconnect switch from cables.
You can feel a knob that is on a spring(ooo err!).
Problem is that it is not coming out far enough.
Grip with pliers and pull. Be brave!
You'll feel it pop out.
Refit everything.
Problem solved.
Took 5 mins.
Commonly caused by removed or snapped split pin in gear pedal linkage.
No need to glue anything to the clutch pedal...please!
Hope this helps.
Pull down the switch
1 - 20 of 37 Posts
