The used 147 I got had a stuck thermostat.
The mechanic changed the thermostat, and the coolant. The car had green coolant before the thermostat change (I read in the manual it should be red, but Im in southern Greece, temperatures never go under 0c, so I guess its some cheaper/hotter alternative)).
The mechanic put green coolant again (no idea about the brand/type), did all the bleeding, rechecking etc, and handed me the car with the coolant exactly at MAX when cold. But he told me to watch it cold over the next few days, and that probably It would drop since there might be trapped air. He told me that after it settled on a level, to bring it back so he could add a little more and bring it to the MAX again.
Indeed, over a week it dropped exactly over MIN, and seems to have stayed there. I'm going back on Monday to fill it up like we discussed, but I wanted to verify if using the green coolant, and this level drop over the first few days is normal.
