Hi all,
I've got a very low bite point on my clutch, was going to bleed it through as the pedal moves about an inch of free travel before doing anything. Had a look at the master in the footwell and fluid is leaking out of the pushrod/end seal. Has anyone on here changed the cylinder? Do I have to remove and replace or can I buy a kit with the rubbers and replace insitu?
any help received with thanks, Art
L
you need to replace the unit. best to remove the driver seat to get better access, even then you need a rubber back & hands with fingers longer than ET
It's tight to remove the hose from the engine side, eper recommends removing the intake manifold, which I didn't bother with, most of my time was spent removing the hose from the reservoir, ended up chopping it off, apart from that it was fairly easy
