hi im new to this so bear with me ive got a 147 ts 1.6 on a 02 platedone 100k . my problem is when i start the car i canot get any gear at all but if i leave the car running for aprx 5 mins i can get all gears and drive no probs my bite is just under half way and there are no signs of fluid loss can any one shed some light on this please :confused:
Weird one as it leans towards a clutch problem but its anyones guess.I recon if you got an experienced mechanic to listen/drive it you would be half way there.
L
i'd suspect the slave or pressure plate, either require the gear-box to be removed.
you cna 'report' the dulpicate posts to the site Admin, click the Yellow Triangle of each post
thanks to all for the help it did just need the clutch bleeding bought a easy bleed kit and away it went thank you all :cheese:
