Hi, i've got a 2001 147 with aircon (not dual climate). The air con dosen't seem to be working ie not blowing cold air, when i switch the aircon on there seems to be no extra load being placed on the engine revs stay the same etc and i can't really here the compressor kicking in, having not had one of these cars with working a/c i don't know whether this is normal or not. Can anyone give me a bit of advice as to what may be the problem hopefully it'll just need a regas and service but you never now with this type of car!
The revs shouldn't vary when the compressor kicks in as the ECU maintains a constant idle speed irrespective of load. You should, however, hear a click as the compressor clutch engages.
you should hear click from compressor ..... could be needs regassing or pressure switch is faulty or over gassed or electrical problem ,but do use a professional not kwik fit or likes as these guys,dont know how to fix if ya got problem
I'll try getting somone else to switch it on/off see if i can hear the click. I generally avoid Kwik-fit at all costs anyway due to issues in the past when i used to run a lease car and had no choice but to go there.
