1 - 14 of 14 Posts
Welcome to the "How To" section of the Alfa 147,156 and GT.
Buyer Guides
147
Alfa Romeo 147 Buyer's Guide
156
Alfa Romeo 156 Buyer's Guide
GT
Alfa Romeo GT Buyer's Guide
Transmission :
Selespeed Info
Selespeed Clutch Rod Adjustment
Replacing the Selespeed Gearbox
Fix 147 manual stiff gearchange.
How to fix stiff/sticky gear problem (bushes)
Gt jts gear lever position
GT jtd stiff clutch
DIY: Gearbox oil change JTS engine
Electrical :
MAF INFO
JTS Diagnostic Logs
ECU Reset - It's A Miracle Cure !!!!
Reducing alarm beep volume 147
HOW TO INSTALL AFTERMARKET HEADUNIT - a guide for 147, 156, and GT
156 side light bulb change
GT headlight bulb replacement
Fixing a buzzing headlamp adjuster (147/GT)
Parking Lights staying on fault - easy fix
Air bag light fix
Reverse Light Switch Wiring Repair
Heated seat switches... Alternative fix
GT Clutch/Cruise Control switch FIXED
Fixing the boot latch microswitches - 147 / GT boot light does not work.
Quick fix for non-working boot light alfa 147 / GT
Boot lock microswitch help - photo? Post 8 is the same for the 147/GT
156.net saved thread - Radio power feeds guide - Feb 2008
Strange electrical faults fixed
Which Battery for GT
Fixing 147 boot actuator
Engine :
How to change the EGR valve
How to fix the EGR Valve
How to fix the EGR Valve #2
Sensor Locations
How to change a thermostat on a twinspark
How to change the alternator belt and tensioner on a 2.4 JTD 10v engine
How to change the alternator belt and tensioner on a 2.4 JTD 10v engine - alternative thread
Auxillary Belt and Tensioners
How to remove/replace the JTD inlet manifold.
2.0TS manifold switching anyone?
A few subtle JTS improvements you could make
GT air con drain pipe location - help!
Gear shift adjustment
Variator solenoid fiy repair guide
JTD/JTDM MCSF & other problems FIX
My solution on Alfa 156 idle problem
JTS Engine Overhaul
Servicing :
How to do the 42,000 Service on a GT JTD
How to change air filter 2.4 JTD 10V 150
Where to Put Axle Stands - Photo?
Interior :
How to change a key blade on a 147 fob
Removing trim inside the rear hatch
How to change the door check strap/door card on 147 and GT
How to fix the GT parcel shelf rattle.
Window Regulator Replacement
Repairing a GT / 147 climate control unit
How to: Replacing steering wheel buttons
147 air cond water leak on passenger carpet
Alfa GT headliner - window leak
Gt window letting in water
Alfa 147 Double DIN Fascia too big
Bodywork :
How to remove a 156 front bumper
DIY PROJECT/STEP-BY-STEP GUIDE: modifying GT front repeaters to 'clear'
How to change the wiper linkage on a 147/GT
Removing a door card on a 156
External door handle broke GT/147
exterior door handle broke :(
Replacing a wing on my 147
Definitive GT tailgate rattle fix from ALFA
Removing the GT front bumper
www.youtube.com/watch?v=7oR32-Ll3_M
GT - So this is why my mirrors won't fold.
156 accidents
Administrator
Alfa 159 1.9 JTDm Sportwagon
New info links
Please post below links to threads you would like adding to this sticky.
If possible please indicate if it covers the 147, 156, GT models or specific to one.
JTS problems solved?
The JTS has long been known as a problem child. Inlet carbon issue, oil burning and then there are the EML faults.
It needn't be so but it will take a rebuild. I was hoping to address inlet carbon build up without taking my engine apart but in 30k miles, it appears not to have built up carbon again. My tips are don't let it idle, decent fuel and oil.
Combustion gas backwash is greater at lower engine speeds and when running stratified mixture (at less than 1500rpm) carbon particle emissions can be 10x as much as with stoichiometric mixture.
There is a link about carbon build up;
https://www.alfaowner.com/Forum/eng...179179-2-0-jts-inlet-carbon.html#post17440309
That link then links to JTS oil consumption. This is solved with oil drillings in the piston, in the valley for oil control ring and Goetze pistons.
Direct link;
https://www.alfaowner.com/Forum/eng...-v6/694953-excessive-oil-use-156-2-0-jts.html
Other than that, use V-Power or Ultimate to keep injectors good and avoid phantom O2 sensor/cat fault codes. I changed my wideband sensors at 103k. ACF-50 spray stops O2 sensor multi-plug terminals oxidising.
At some point I'll sort out ignition coil multiplugs but in the meantime, change spark plugs early as the ignition coils are weak.
A good point to note is a JTS remap by Stefan at Squadra Tuning disables the stratified mixture and relaxes fault code thresholds to be more suitable for real world conditions.
Rear spring/damper replacement video
I found a good guide about rear suspension replacement by Italia Autos;
Some other tips:
1. Sometimes using an impact gun on the lower strut bolt helps free it. It can save a lot to effort.
2. Be prepared to use plenty of penetrating fluid. There are better ones than WD40. PlusGas is a good choice as is a graphite impregnated fluid.
3. Leaving the strut top nut in the boot on by 2 or 3 threads prevents the strut dropping out if a prybar is needed to displace the strut.
4. Once the strut is out, a thin wall 22mm socket is needed to fit inside the strut mounting to remove the strut mounting.
5. Often carrying out any work means a rear strut mounting may fail a few months after doing spring/damper replacement. If you don't want to do the job twice, a new mounting makes sense.
6. The rear ARB link may not be save able. I recommend using extra washers or fitting the old nut on top of the new nut but only tight enough to hold it on. This prevents needing to wind the securing nut over corroded exposed threads should subsequent work be needed.
7. Use a wire brush/emery cloth to clean corrosion from exposed bolt shafts. Coating with copper grease before reassembly or Bilt Hamber Dynax S-50 after reassembly reduces the chances of things corroding up again should future work be needed (if you live in a climate similar to the American rust belt).
Administrator
A lot of new how to's tips have been added so take a look.
1 - 14 of 14 Posts
