Hi there new to alfas, have owned my 147 6 months no probe, then 2 weeks ago the alternator dies on my (5 mile from home), so found a replacement other day and replaced ( from top) car was fine for 2 day then mcsf flashed a couple of times but went off, next day came on and has stayed on? Car seems to be running ok, but not quite reving right any ideas? Thanks for any help
It could be a number of things, you need to see if a specialist or forum member close to you can read the ecu codes.
Post them on here and someone will be able to advise
Hi there again have had it looked at by garage, and he reset the ecu (light went off) any he said that it was showing up as a leak after the maf ,also he said I had a leak at the downpipe, could this cause the mcsf light to come on? Light has come back on day after? Cheers in Norwich if anyone one local
