147 1.5 TS lubricants
Hello everyone from a newbie! Just checking the levels on my wife's 147 ( 5 speed manual) and noticed the power steering oil needs topping up. Checked the manual and it recommends ATF Dexron II D LEV, SAE 10W oil for the power steering. I can only find Shell Donax TX ATF Dexron III in the local garage. Can I use this to top up the power steering level? Thanks for the help!
Banned
Re: 147 1.5 TS lubricants
Delta492 said:
Oops sorry about the typo! That should be 1.6 TS of course!
Castrol rs 10/60 oil or selenia fully synthetic oil(any alfa dealer will stock this) or Motul sae 15/50 engine oil or Mobil 1 15/50 oil.They are the best of the best oils to use for the engine.As regards the power steering fluid go to your alfa dealed and get it there,The Shell Dexron is just as good, and might be a bit cheaper to buy in your local motor factor shop.Good luck
Dexron III is backwardly compatible. Don't put Dexron II in where Dexron III is specified though.
For engine, my thread Oil Recommendations lists all the grades, just do a search.
Simon
