Hi guys!
I want to change the battery of my 147 1.6 TS 120hp 2007 but to locate its specs I need to disconnect it first (the sticker is under the fuses on the positive pole).
On top of this, I'm not sure if the one currently fitted is the correct battery...
Does anybody know the Ah and CCA that Alfa Romeo uses for this car? (I want to order it online)
I checked the owners manual but it doesn't mention the specs.
Thank you and Merry Christmas!
You need a battery 242mm long, 175mm wide and either 175 or 190mm high.
The 190mm high is an 027 type (ie Bosch S5 005)
Check the height that your battery strap can take.
