Just about to complete an oil change and whilst cleaning around the sump plug hole, bits of metal fall out.:eek:
Then, horror of horrors, sump plug, although it screws in, keeps on spinning.:cry:
Time for a new sump or
Tap and helicoil
Damn, blast. All 5 previous oil changes (not all on this Alfa) went just fine.
Failing that, alfaworkshop (i think) do a tapered plug.
I'll go for the tap and helicoil first. Any ideas on cost? Previous suggestions on this forum are £50 - £90.
The tapered plug from Alfaworkshop probably wont get to me till Tuesday.
I'm still kicking myself!!!!
I knew there was something wrong when after the last oil change, the plug took a long time to close and seal! The 5 prior oil changes I did not do.
Update:
I'm giong to have to move the car about 8 miles (PTFE job me thinks) to the nearest place that has tools large enough.
Sump plug size is M16 with a 1.5 pitch.
Why do Alfa make them soooooo large?
the problem is the steel plug and aloy sump, these metals react chemically and ''weld'' together in time.. they shouild have made a steel threaded insert in the sump... but that costs money...
Use copperslip when you reinsert the plug...
C
Update:
So that the oil comes out...
Its a common problem and not your fault BTW.
Got it fixed using tap and helicoil. Was actually an M18 plug. £50.60 and the guy changed the oil. Rugby Motor Engineering Services.
