how do you change the bearings on the rear radius arms of a 146ti been told by my local garage that a specialist tool is needed but the seller of the kit said otherwise.
W
Do you mean the trailing arm bushes?
If yes, and if they're the same as 155s there's no special tools needed.
wrinx
I've done one. It depends if the bolt that runs through has rusted into the sleeve.
If that has happened you will need a bi-metal hacksaw blade pack (£4) B&Q and a reciprocating saw (£29) argos
You will then cut though the bolt on both sides to free the radius arm and you can drift the innards out with a big hammer.
Shop 4 parts sell the bolt and bearing races for about £28.
If the rusting hasn't happened it's an easy job.
These are the same/very very similar to those on the Fiat Punto of which I have done 2. I've posted a guide on the Fiat Forum website as how to do it. It's not difficult, just make sure plenty of grease is pushed into the cavities and bearings. I obtained the kits for about £10 each from Desira.
Standard tools required, a suitable drift and a big hammer (and some care pressing new races into place). I did it at home.
http://www.fiatforum.com/punto-guides/56642-new-trailing-arm-bearings-fitted.html
