1 - 11 of 11 Posts
Hi Everybody,
I need help. I want to tart up the engine bay in my 01 Cloverleaf. I'm getting a slow drip from my coolant so i want to change the hoses. Anyone know if samco do a hose kit for the 145? Would a 147 kit or 155 kit fit it instead?:confused:
Please Help!!!
Yeah, I forgot to mention that bit, and the 147/156 ones wont fit.
No experience myself but apparently you need the 147/156 ones if you have a plastic top engine. Can anyone definately confirm this?
Hi guys,
That was some quick replies!!
My engine is the plactic top CF2 version. I'll send a few emails and see if the gtv engine is the same. Anyone on here know??
i have an alloy topped car and i bought a 155 kit and it fitted fine.
then i changed the rocker cover to put the plastic cover from a JTS engine on, this either meant cutting the cover to miss my expansion bottle or fitting the later bottle (i had one to use)
to join the two together i bought a 45 degree and a 90 degree bend (both 19mm) from demon tweeks along with an alloy joiner, a little trimming and all is fine.
1 - 11 of 11 Posts
