My cooling system bleed screw above the thermostat housing is stuck. i am afraid i will strip it.
Could anyone help with some ideas to try to get it loose or some other innovative ways of bleeding the cooling system?
Giulietta 116
14mm 6 point hex socket should do it.
it is soft brass/copper material and a 12 point socket/spanner will most likely round the edges.
once loose a few turns a small bleeder hole is exposed, its only about 2mm in diameter.
if you cant crack it, just pour new coolant slowly and top up next drive, or loosen a top radiator hose.
Good timing mine needs loosening too.. I assume that its anti clockwise to loosen?
