1 - 10 of 10 Posts
Are they all the same?
Ratios/Strength etc.
What I am getting at is can you use any box with any engine?
Ta.
:D
As far as I know all gearboxes have the same ratios in the 105/115 series except for the 1300 and the last two series of the spider (aerodinamica and series 4).
ratios 1600 / 1750 / 2000:
1 - 1:3.304
2 - 1:1.988
3 - 1:1.355
4 - 1:1
5 - 1:0.791
R - 1:3.010
I don't know about the strength, but I suspect they are all the same. They share the weak second gear for sure :D
Hans. Have you done a spread sheet for the Revs/Speed, for the 105's like the 147/156 one.?
I would love to be able to check the speedo, but not sure what the actual revs to speed ratio is.
Haven't done it. But I will make one tonight for you.
I can't make the excelsheet because the final ratios are a problem. Depending what book or article I read, the final ratio of the 1750 GT Veloce is sometimes 4.555 : 1 and sometimes 4.1 : 1 :mad:
I can't find a reason for the differences like model years or so :(
Does anybody know?? :confused:
Hans, I will check my owners book tonite, but could it be an option on the sheet, or does that make it to complex?
Final drive ratio's are as follows.
Sprint GT 63-66 1570cc
4.555 to 1
1300 GTJ 68-74
4.555 to 1
1750 GTV 67-72.
4.1 to 1
2000GTV 71-76
4.1 to 1.
1600 GTA 65-69
4.555 to 1
Spider 1600 66-67
4.555 to 1.
spider 2000 71-82
4.1 to 1
The Gear ratiois tend to be the same, except the the 1300's seem to have 0.860:1, for the 5th, as appose to 0.791:1, on the 1600 to 2000 Engines.
This data is quickly taken from Richard Bremners Book.
The handbook for my 1750 quotes actual drive ratios as below.
1st 13.54:1
2nd 8.15:1
3rd 5.55:1
4th 4.1:1
5th 3.24:1
This is with final drive of 4.1:1.
Tyre size BTW is 165x14, not sure of the profile tho.
To answer Ricks question, they probably are the same box, but the 5th Gear will be different on a 1.3 Junior.
Some GTA's are probably different as well, for Racing reasons.
Too bad I can't find the height of the tires anywhere. But if I am not mistaken (I calculated the result) the height is 80%
You can download the file over here
1 - 10 of 10 Posts
