Can anybody confirm if the 2000GTV is OK on unleaded?
Ta.
Ta.
Most People seem to agree that they are OK with super unleaded. Alloy Engine with alloy head, means it allready has Hardened valve seats anyway. Sodium filled valves also help.RicksAlfas said:Can anybody confirm if the 2000GTV is OK on unleaded?
Ta.
It's probably me being a bit alarmist, but at the time of leaded being phased out, the "mags" were saying that LRP was only suitable for cars used for pootling about in, and the LRP makers were very conservative saying "moderate use" "light loads" "no towing" etc. etc. The general feeling was that if you were going to fly about like your pants were on fire, use unleaded (or super unleaded if you need the Octane) with a lead additive.alfatastic said:Wooops always get those 2 mixed up, why is LRP so bad!
IanM said:Most People seem to agree that they are OK with super unleaded. Alloy Engine with alloy head, means it allready has Hardened valve seats anyway. Sodium filled valves also help.
I was assured mine had been running on unleaded for a while, and I intend to use it as well. When LRP is available and convenient, (as it was on Sunday by pure luck!), I will probably put that in anyway, but not as a rule.
83P a litre is a bit eye watering.![]()
How old is 'very old' Hoygs?, 1968 I suppose is middle aged but not old...Hoygaard said:No need to go for leaded fuel, unles your Alfa is very old. All the Nord engines have reinforced valves and valve seats, no need to lube'm with lead. However, if you cant get hold of 98 RON, have the timing slightly (2 degrees) retarded from the factory settings to allow trouble free 95 RON usage![]()
Hoygs
Thats Ancient..............wrinx said:.....and I'm looking at 1953![]()
wrinx
