I have a year old Giulietta 1.6 Diesel. Only bought her February 2016 so I only have her a few months.
All going fine so far but just have two tiny niggles. I've brought her back to the dealer about them already and they said it was all in my imagination probably but I think you need to be driving the car for a while before you notice them at all.
Niggle 1:
Firstly the stop start. How often should it work in real world driving? I mainly drive her through town but generally with little traffic delays but I do a lot of motorway or fast secondary road driving also. It just seems that the start stop system only kicks in maybe 10% of the time at best. Its probably working maybe 1 or 2 days each fortnight. So the Start Stop turns the car off each time I stop during the period of a commute to work one day but then I won't see it work again for another 7 days or maybe longer. Is that normal? I would have thought it would be more frequent than that. I know it only works when the system can cope with it. I drive it in Natural mode 99% of the time as well and I don't have air con on generally so there is no stress on the system beyond the minimum you can generally expect.
Niggle 2:
I've noticed after a few days of driving the car when I got it that going from 1st to 2nd gear isn't as smooth as all the other gears or as smooth as going back down from 2nd to 1st gear. I just feel a slight resistance and a "clunk" as I put her into 2nd gear from 1st. Not all of the time but most of the time. Seems a bit more obvious when the car is started in cold weather. Playing around with it at different rev regions and what have you makes no difference but I did notice that if I delay putting her into 2nd slightly, by maybe a few fractions of a second then the resistance is lessened or gone and the "clunk" feeling can be more or less avoided. Unfortunately its not ideal as I am losing momentum by doing so. The dealer mechanic said he didn't notice any resistance or if he did then it was normal when I brought it back and he test drove it but he was driving it about 5 minutes after I arrived from a long journey so the system was warmed up. Its not a major issue that I am worried about but it definitely feels stickier and clunkier going into second compared to all the other gears which feel nice and fluid as you'd expect. Could it possibly be an issue with a synchro? The fact that it isnt as sticky if I give it that half second before putting it into gear suggests something isnt 100% right.
Thanks!
Niggle 1:
Niggle 2:
Thanks!
