1 - 10 of 10 Posts
Hi All,
I have a 1.7, 8v engine, which was fully rebuilt buy Vulcan Engineers in 2009,
Spec,
Mechanical tappets,
Colombo & Bariani camshafts (Road max),
Adjustable vernier camshafts pulleys,,
Hi compression pistons 10-4-1.
Uprated big end bolts,
New big end bearings
New Main bearings
New piston rings.
New cambelt and tensioners
New water pump
lightened, balanced and blueprinted.
There is no carburettors, linkages our distributor with the engine.
I purchased this engine in a 33 with a blown head gasket, the intention was
to convert the car for track use, the head gasket blew, due to a split
pipe, both head gaskets were replaced (and cambelts) and i ran the car for a couple of months,the only fault was a slight tap on one of the heads from the tappets, which
obviously just needs adjusting, the actual engine since rebuild, has covered
very little mileage, the engine has been in storage for the last 9 months,
i broke the car for parts, because i could not sell for its true value.
Open to serious offers, before listing on ebay.
Thanks Liam 07957352910
Hi All,
engine sold to Mark, (woody) this morning, he came over early and
picked it up, nice to put a face to the name, Thanks again Mark,
was nice to have met you.
Liam
Thanks Liam, Engine exactly as you described it!:thumbs: Good to meet you too, I,ll have to have a ride over your way in the spring when it has been fitted! Thanks again Mark.
K
if you come across a set of coilovers laying around liam mate that you want shifting then let me know :D
K
steady mate, very steady.
must get my finger out with all the talk of a summer track day :D.
1 - 10 of 10 Posts
