Is this something to worry about? Can I clear it?
Also the system is telling me that both the driver and pax seatbelts are fastened.. em.. they aren't... :rolleyes:
If I was you I would clear it to see if comes back again and check the battery voltage with a voltmeter to see if it is normal (I don't know what normal is myself). The airbag ecu is right between the drivers and passengers footwell, maybe try cleaning out those connectors after the battery has been disconnected for about an hour or so.
To be honest I am not sure if my reply is that helpful as I haven't had that airbag problem before.
L
clear it.... it's just a warning that the battery voltage dipped below a certain voltage either due to flat batttery or during strating the car in frosty weather when the battery was under strain.
Cool, so not a major drama then by the sounds of it... :)
